Distributor shopping...
Old Jul 30, 2002 | 07:16 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Distributor shopping...
I have a 97 CX and want to swap a CRVTEC, which distributor do I need? My friends said get a 96+ Gsr distributor, but what are my alturnatives?
Old Jul 31, 2002 | 11:52 AM
IlikeTODA's Avatar
Default Re: Distributor shopping... (GapxGuy)
You need an OBD2 B series VTEC dist. Since you have a 97 CX you will need to get a dist that is no newer than a 98. The plugs from a 99-00 are different than the 96-98.
Thanks, J
[Modified by IlikeTODA, 8:54 PM 7/31/2002]
Old Jul 31, 2002 | 01:13 PM
GapxGuy's Avatar
Default Re: Distributor shopping... (IlikeTODA)
So pretty much my only choice is to get a 96-98 GSR dist? Thanks for you input.
Old Jul 31, 2002 | 02:36 PM
JDM EG2's Avatar
I have an OBD2 vtec distributor. I will sell it for $150 plus shipping. My email address is turbob16@bellsouth.net . Let me know if your interested.
Old Aug 1, 2002 | 03:33 AM
Jeff C's Avatar
what ecu are you going to be using?
Old Aug 1, 2002 | 10:41 AM
GapxGuy's Avatar
Default Re: Distributor shopping... (Jeff C)
I'm currently using an ITR ecu.
Old Aug 1, 2002 | 09:51 PM
Halo's Avatar
If your cash flow is tight you can use a LS distributor, using the bolt inn the 12 o clock position
Old Nov 26, 2002 | 02:01 AM
GapxGuy's Avatar
Thanks, J
Is this true? If so I have a 2000 Si distributor for sale.
Old Nov 26, 2002 | 05:35 AM
Jeff C's Avatar
Just repin the plug to work. Match the colors and you should be alright.
JaSoNe
Aug 16, 2006 06:52 PM
Gokustyle
Aug 16, 2006 06:49 PM
civicb16eg
Northern California (Sales)
Jul 1, 2006 03:12 PM
wizzards581
Oct 27, 2003 05:00 PM
JDMITR222
Jul 23, 2002 03:34 PM
