ABOUT DISTRIBUTOR...
Old Oct 27, 2003 | 04:47 AM
wizzards581's Avatar
Default ABOUT DISTRIBUTOR...
WILL ANY B-SERIES VTEC DISTRIBUTOR FIT ON ITSELF? EVEN OBD2?
Old Oct 27, 2003 | 05:31 AM
samagon's Avatar
Default Re: ABOUT DISTRIBUTOR... (wizzards581)
generally it is acceptable to not use the caps lock exclusively when typing.
I would assume that for a B18- that the distributor should be interchangable. Probably it is easiest to call up honda as them for a PN on a distributor for one B series, then call them again, and ask for the PN for a different B series.
I do know that from OBDi to OBDii you are going to see no difference in the distributor, as the only differences are going to be the sensors.
Old Oct 27, 2003 | 03:46 PM
Default Re: ABOUT DISTRIBUTOR... (samagon)
so i can use obd2 to test on my obd1? what about just the distributor caps?
Old Oct 27, 2003 | 05:00 PM
thrty8street's Avatar
bump
98JDM_Type_R
Aug 20, 2004 04:42 PM
98JDM_Type_R
Aug 20, 2004 03:02 PM
98JDM_Type_R
Aug 20, 2004 02:54 PM
