Difference in Axles for 96-00 Civics
Old Dec 9, 2003 | 01:37 PM
vtecb20coupe's Avatar
B A N N E D
Default Difference in Axles for 96-00 Civics
is there a difference between the axles for a 96-00 civic ex and 99-00 si? i know when you swap a b series motor into the 96-00 sohc, you don't change the axles. i need to replace the passenger side axle on a 99-00 si, and want to make sure the splines, etc will match up. thanks.
Old Dec 9, 2003 | 04:11 PM
DA6righthand's Avatar
Default Re: Difference in Axles for 96-00 Civics (vtecb20coupe)
sry i cant answer ur question but do you happen to know if stock jdm ITR axles will fit a 96 civic hatchback?
Old Dec 9, 2003 | 04:42 PM
MADEinJAPAN's Avatar
Default Re: Difference in Axles for 96-00 Civics (nohondayet)
For your 96-00
All 92-00 SOHC Axles are the same, and they are only for SOHC motors.
All B-sereis Axles are the same and only work for B-sereis motors.
Old Dec 9, 2003 | 04:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nohondayet &raquo;</TD></TR><TR><TD CLASS="quote">sry i cant answer ur question but do you happen to know if stock jdm ITR axles will fit a 96 civic hatchback?</TD></TR></TABLE>
ITR JDM axles
96-97 are 32mm and will work for any B-Series
98+ are 36mm outers and will only work in 98+ 36mm jdm 5lug
Old Dec 10, 2003 | 05:32 AM
B A N N E D
Default Re: Difference in Axles for 96-00 Civics (MADEinJAPAN)
thanks. happened to pick one up.
EM1R
Aug 20, 2005 11:28 AM
HYBRIDHATCH92
May 19, 2005 08:50 AM
turkdog
Nov 27, 2003 04:05 PM
