Damn distributor..please help
Old Jul 26, 2002 | 02:36 PM
gsrvx's Avatar
New User
Default Damn distributor..please help
Ok...so I was throwing code 9 (cyp sensor)...because my rotor screw came loose and all hell broke out. I just replaced the distributor housing, rotor, cap, leak cover, except the ICM (igniter unit).
Fired up the car...ran fine for 5-10mins as I set the timing. Shut car off.
Come back...turn on the car...notice my tach bounce up and down from 1-3rpm rapidly...but then seems fine...after driving for 3 mins...car dies. Turns on...then dies...now won't start up.
Do you think it's the igniter?
-Rod
Old Jul 27, 2002 | 12:06 AM
IntegD's Avatar
New User
Default Re: Damn distributor..please help (RK)
Had a very similar problem, my tach bounced and died. It turned out to be the ICM. I guess the only way to be sure is to maybe try a friends(if one is available) or test voltage and compare to what the HELMS says. Good luck
4cefedcrx
Apr 7, 2004 07:15 AM
gsrvx
Jul 26, 2002 08:00 PM
gsrvx
Jul 26, 2002 03:27 PM
gsrvx
Jul 26, 2002 03:11 PM
Timmayeg
May 31, 2002 05:03 AM
