DA vs. DC rear mount poly insert?
Old May 4, 2010 | 02:58 PM
integrawow's Avatar
Default DA vs. DC rear mount poly insert?
Okay, I was digging through all my old stuff and found a brand new pack of Energy Susp. motor mount inserts for my old 91 integra. I know that the DC2 has a different insert kit part number, and I know that it is probably due to the DC's front lower engine mounts. What I want to know is if I can at least use the rear mount insert from the old teg kit?
Hey it's not costing me anything since I have the things just setting there. I can just window weld the DC's lower fronts to have a pretty decent cost savings. Ha ha, I look so cheap with this thread.
Old May 6, 2010 | 09:41 PM
HAMOTORSPORTS's Avatar
Default Re: DA vs. DC rear mount poly insert?
The rear engine mount on the DA is more square in shape than the EG/DC mount. You may be able to squeeze it in, but you'd be better off selling the bushing set and buying the correct ones. Good luck
DarKStaR5
Mar 6, 2008 08:08 PM
mike93eh
Jul 29, 2005 02:28 PM
Greg456
Apr 8, 2004 09:49 PM
ragejed
Jun 25, 2002 07:22 AM
