DA and B18B swap question
Old Apr 1, 2004 | 05:54 PM
Rah Rah's Avatar
Default DA and B18B swap question
Yes I've searched, but I want to make sure I have everything. My current setup is a 92 LS with a 90-91 b18a1 (don't ask). As you can imagine it's a mix and match type deal as it is. I'm replacing it with a JDM b18b. From what I gather all I need is the following:
1. map sensor--option to either use the map sensor on the firewall or extend wires and use the b18b throttle body map sensor.
2. A/C and power steering brackets--use the all of the DA's.
3. crank pulley--use DA's
4. distributor/fuel rail/injectors--use DA's
Is this accurate? Most of the posts I've found were 90-91 tegs. If I"m missing anything let me know guys.
Old Apr 2, 2004 | 11:16 AM
Scott - 93HB Si's Avatar
Default Re: DA and B18B swap question (Rah Rah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rah Rah &raquo;</TD></TR><TR><TD CLASS="quote">1. map sensor--option to either use the map sensor on the firewall or extend wires and use the b18b throttle body map sensor.
1. JDM motor usually don't have MAP sensors on them, they are usually all firewall mounted.
2. Yes.
3. Yes
4. Yes - but the distributor from the JDM motor should work fine if it's OBD1 (since your car is 92 it's OBD1 - hopefully - considering the motor's been out already).
dwebb57
Nov 17, 2013 07:58 PM
civicegb18
May 18, 2010 08:46 PM
mangabay
Jan 25, 2008 08:50 PM
vteg94
Dec 26, 2007 02:35 PM
DXK Eg
Feb 11, 2005 05:05 AM
