d16z6 distributor question,,,,help.
Old Aug 4, 2002 | 07:30 PM
civicwagonman's Avatar
Default d16z6 distributor question,,,,help.
what exactly is the difference between a 93 civic dx dist and a 94 d16z6 dist? does the p28 have to have the vtec dist? got my 90 civic running tonite obd1 but check engine lite is on. also, how do you check codes on obd0-obd1 conversions? so many questions, so little time.
Old Aug 4, 2002 | 07:51 PM
Default Re: d16z6 distributor question,,,,help. (civicwagonman)
anyone? somebody has to know.
Old Aug 4, 2002 | 09:29 PM
SCsol's Avatar
the only difference between the two is the placement of the mounting hole besides that is should work what ECU are you using OBD1 or 0 that will help me help ya
Old Aug 5, 2002 | 05:35 AM
Default Re: d16z6 distributor question,,,,help. (SCsol)
its a 94 si p28 obd1 wiht 93 obd1 dx dist.
Old Aug 5, 2002 | 10:13 AM
lelopez's Avatar
The way you check the codes is by jumping the timing check connector that is located by the passenger side footwell.
L.
Old Aug 5, 2002 | 12:07 PM
Default Re: d16z6 distributor question,,,,help. (lelopez)
when i turn on the key to the run position, without starting the motor, the engine cel comes on with the fuel pump, then goes off fo r a second, then comes back on and stays on. same way it does with it running. tried jumping the connector, didn't do anything. traced the wires and they are all hooked up correctly between the jumper and the computer. I guess I'm gonna have to go thru wire by wire and check everything again. any ideas? oh, I also tried pluggin in the 93 dx computer but cel did the same exact thing.
[Modified by civicwagonman, 1:09 PM 8/5/2002]
dmeconitas
Aug 21, 2015 10:32 AM
miasma
Feb 5, 2007 04:24 AM
Conclusive
May 30, 2005 11:06 AM
untitled
Aug 5, 2003 05:44 PM
civicwagonman
10
Aug 8, 2002 07:29 PM
