ctr piston?
Old Jan 27, 2003 | 12:02 PM
black-hatch's Avatar
Default ctr piston?
ok i want to put ctr pistons in my b16a2 are they the same size as stock ones and when i put them in will i need to richen the fuel mixture and if i do from what rpm to what rpm also what should i retard timing to thxx?
Old Jan 27, 2003 | 01:55 PM
Jeff C's Avatar
Default Re: ctr piston? (black-hatch)
Yes, the ctr is a b16 too but with higher compression. They are both have the 81mm bore. I would think you should not need to mess with the air/fuel. :shrugs:
Old Jan 27, 2003 | 02:04 PM
function83's Avatar
Default Re: ctr piston? (Jeff C)
you will have to shave the rod 1mm on each side to fit the ctr pistons.
pic credit: katman
Old Jan 27, 2003 | 05:02 PM
Patch's Avatar
Default Re: ctr piston? (djhatch)
Whats the CR with CTR pistons in a B16A?
Old Jan 27, 2003 | 06:24 PM
speedy-crx's Avatar
i have ordered some ctr pistons for my b16a first gen would i need to do this to and if so would it work without this done and if i had to do it were would i take it to get it done
Old Jan 27, 2003 | 06:28 PM
owen_the_soyboy's Avatar
Default Re: ctr piston? (needahatch)
any capable machine shop / engine shop can mill the 1mm off of the rods for not much $$$.
yes you will NEED to do this unless you have GSR/ITR/CTR rods.
Old Jan 27, 2003 | 06:33 PM
speedy-crx's Avatar
Default Re: ctr piston? (owen_the_soyboy)
hey man do you have any info on lsvtec if so aim me pissdrunxracer
Old Jan 30, 2003 | 08:16 AM
X0's Avatar
X0
Are CTR pistons/rods a good mod for a b16a2? Do you need to do any other "prep work" before running them, or can you just throw them in and go?
Unphzd
Oct 6, 2011 12:07 AM
trucdoken
Sep 26, 2005 09:46 PM
SiBuddy00
May 15, 2005 10:33 AM
JsNA99si
Apr 16, 2004 12:10 PM
MikeMAN
Oct 17, 2002 11:39 PM
