crx coverted to obd 1 with code 20
does any one know how can i get rid of this code 20 electrical load detector.. my car cranks but only when you jump the starter.. also its a home made conversion harness lol..
my main relay is good makes the clicking noise, so is my starter relay.. i cant figure out how to get rid of this code.. HELP ME PLEASE!
The code 20 should not be affecting the starting of your car, you have multiple problems. The starter issue sounds like a problem with your ignition switch. Also, the most common cause of the ELD code is a broken wire at the underhood fuse box, where the wires for the ELD enter it..
from what i understand, if you have a ELD code, then usually there are alternator or idle problems. i recently put in a chipped P28 and got the code 20 which wasnt there before. i'm not having any idle or electrical problems so i am ignoring the code for now until i know more about it. if you ELD is in fact broken, replace you underhood fusebox. also do a search...
Modified by n-line4 at 6:27 PM 10/17/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbofienD 04 »</TD></TR><TR><TD CLASS="quote">you dout my wiring brian?
its not that i doubt it, but you could of easily made a mistake, even me or any1 else....but im 99% sure its the wiring..
</TD></TR></TABLE>its not that i doubt it, but you could of easily made a mistake, even me or any1 else....but im 99% sure its the wiring..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenfiend 04 »</TD></TR><TR><TD CLASS="quote">how bout ill waste as much time as i want</TD></TR></TABLE>
you do that...hope its running b4 you get your liscense.
slowteg0bd1
Mar 4, 2009 09:13 AM
