crx b16 o2 sensor question
Old May 27, 2003 | 01:33 PM
crx1856's Avatar
Default crx b16 o2 sensor question
i'm building a turbo b16 in my rex using hondata 2b. do i need to have two o2 sensors hooked up or just one. the shop that did my original swap uses just one o2 sensor on the exhaust manifold.
Old May 27, 2003 | 02:12 PM
crx1856's Avatar
Default Re: crx b16 o2 sensor question (crx1856)
also, when my turbo's put in does that mean i need to have 2 o2 sensors plugged into the downpipe?
Old May 27, 2003 | 02:48 PM
raene's Avatar
It depends on what your ECU expects - tell us which ECU you have. I don't think Hondata requires 2 O2 sensors but I'm not sure if you're running a PR3... or if the S200B is even available for the PR3
Old May 27, 2003 | 07:39 PM
VTECVillain's Avatar
Default Re: crx b16 o2 sensor question (raene)
If your ECU requires 2 O2 sensors then it's an OBD0 PR3 or PW0. Well it could be a 96+ OBDII but I seriously doubt that. In order to run Hondata would require coverting to OBDI.
Old May 27, 2003 | 10:30 PM
crx1856's Avatar
Default Re: crx b16 o2 sensor question (VTECVillain)
i'm actually running hondata stage 2b on my pr3 ecu. so what do you guys think?
Old May 28, 2003 | 04:25 AM
Davep's Avatar
The problem with the pr3 ecu is it needs to have the o2 sensors in the right location for it to work right. That is hard to do when you have a turbo setup. Your two options are to run the open loop file or your best be would be to switch over to obd1.
justin1785
Jul 9, 2010 02:55 PM
DaiJekBok
May 24, 2007 08:51 PM
Quick 200k Mile Motor
Sep 13, 2002 06:19 AM
shingles
Jan 19, 2002 08:25 PM
