CRX/B16 Driver Side Axle problem
Old May 30, 2002 | 07:18 PM
nsxmatt's Avatar
Default CRX/B16 Driver Side Axle problem
JDM B16 in a 88 CRX DX using HCP Mounts. Motor is in and bolted up, passenger side axle is a 90-93 teg axle and fits great, passenger side was going to be a 90-93 but was too long so we got a 86-89 teg axle. It bolts together but you can tell it's too short plus when you turn to the right the axle binds.
What axle or axle combo should I use??? I thought the 86-89 was the shortest?? We need help since it's the only thing holding us up. Thanks in advance!
Old May 30, 2002 | 09:45 PM
Redline130's Avatar
Default Re: CRX/B16 Driver Side Axle problem (nsxmatt)
The 90-93 Teg axle should fit. Did you remove the spacer on the inside of the hub? Also the plastic/rubber spacer that is on the axle where it meets the hub. What half-shaft are you using?
Old May 31, 2002 | 04:33 AM
nsxmatt's Avatar
Default Re: CRX/B16 Driver Side Axle problem (cyber13)
We removed the spacer but it's still a good half inch too long. We used the int. shaft that came on the engine also. What else could you use?
OmgDelSol
Sep 10, 2014 02:16 PM
sd619jef9
Sep 6, 2012 06:36 PM
border919
Jan 23, 2009 09:07 PM
B18CYAAA
Aug 11, 2007 04:38 PM
Modified Motors
Sep 14, 2004 06:16 AM
