Crank Fluctuation Sensor question
Old Apr 21, 2003 | 06:39 PM
lcopas's Avatar
Default Crank Fluctuation Sensor question
I have a B16B engine from a 2000 model JDM Civic that I am going to out into a '97 EX Coupe.
When I put the new timing belt on the B16B engine, I don't recall seeing the CFS.
Does this engine use a CFS ?
If not, do I need to worry about it it ? And if so, did I just miss it ?
Thanks in advance
Old Apr 21, 2003 | 07:10 PM
SC61HB's Avatar
Default Re: Crank Fluctuation Sensor question (lcopas)
I just swapped in a JDM ITR engine into my EK and learned the CTR and JDM ITR engines don't have, and their ECU's don't look for the following sensors:
- Crank Fluctuation
- VTEC Oil Pressure Switch
- EVAP
- Secondary O2
All I did was cut the plugs off and as much as the wire you can, and just tape it up with electrical tape. Hope this helps.
Old Apr 22, 2003 | 05:35 AM
Trey's Avatar
25 Year Member
Default Re: Crank Fluctuation Sensor question (zgrieger)
If you use the CTR ecu, don't worry about it.
radwarrior
Honda CR-V & Element
May 21, 2019 12:29 PM
rig9896
May 22, 2013 04:29 AM
86si
Jun 21, 2005 06:27 PM
tyflip2
Dec 5, 2003 08:32 AM
lcopas
Jul 21, 2003 12:03 PM
