Crank crank crank
Old Mar 29, 2016 | 08:29 AM
Xavier Mckinney's Avatar
Default Crank crank crank
Hey guys my civic cranks and cranks and will not start
-Engine is a b20 (obd2) with gsr head (obd1)
I used it to go out and parked it up..few days later crank crank crank no start!
Each spark plug gets spark.
Fuel pump kicks on loud and clear
Just changed the distributor ( does the same cranking even with older distributor)
Checked the main relay it works when I test it
Starter fine... Compression good
Any ideas?
Old Mar 29, 2016 | 08:45 AM
DA9_LEO's Avatar
Default Re: Crank crank crank
Ensure all grounds are intact especially T-Stat ground, also check fuses, such as ECU fuse, do all your cluster lights light up?, did you check Engine Timing? Did you loosen 17mm for fuel rail and made sure fuel is coming to the rail?
Old Mar 29, 2016 | 08:57 AM
Really appreciate the reply. All cluster lights come on .Yes fuel is coming to the rail. I'm going to check the fuses in side the car and the grounds also timing thank you
Old May 4, 2016 | 03:59 AM
Problem was the damn distributor rotor was broken
Old May 4, 2016 | 04:02 AM
THANK YOU EVERYONE FOR THE SUGGESTIONS AND REPLYS
Jeremy Harris
21
May 2, 2016 10:58 AM
Preludelearner
Mar 26, 2015 07:54 PM
WifesVTEC
Jan 31, 2011 04:46 PM
welltal89
10
Apr 4, 2010 03:11 PM
SeaArrExx
Jan 28, 2005 04:19 PM
