Cost and application of EG engine mounts??
2 questions....
1) 95 Si hatch engine mounts will work with a 95 JDM GSR engine, yes?
2) how much should I offer someone for all 5 Si mounts??
Thanks,
-Nick-
Thanks,
-Nick-
WHOA! USE the Civic mounts except for the driver's side mount near the timing belt cover - THAT one should be replaced by an Integra GS-R mount.
In fact, every swap we've done really REQUIRED the two front anti-roll mounts to be from the CIVIC because there's a difference on the framerails on the Civic and Integra - you can use the Teg ones if you want to, but they will NOT fit flush against the Civic 's framerails.
This is coming from someone who has done enough swaps on the ground and witnessed at LEAST 30 at the shop that he works at. (Me
