cooling fan question
Old Jun 20, 2003 | 12:13 PM
thehatchninja's Avatar
Default cooling fan question
apparantly it's a common problem for the cooling fan not to work after a motor swap....i was thinking about tracking down the problem...i already know it's not the relay, and it's not the fan motor, so all that's left is for me to check all of the wires and the cooling fan timer unit...niether of which i'm comfortable doing, especially when it's 95 degrees and probably 85% humidity.
Here's what i'm getting at. I've heard of some people wiring the fan to come on whenever the motor is on. I want to know how to do this.....i know it shouldn't be hard, but i want to be sure before i brave the heat. Thanks in advance
Old Jun 20, 2003 | 12:39 PM
SleeperEG-B's Avatar
Default Re: cooling fan question (thehatchninja)
Take a look - Might help
https://honda-tech.com/zerothread?id=541009
Old Jun 20, 2003 | 12:59 PM
Audipwr1's Avatar
you can just wire it up to a switch and turn it on when idleing or when its running hot
Bo-Deker
May 9, 2014 01:44 PM
jlowellintegra
May 30, 2011 07:52 AM
josemt
Jun 23, 2010 06:24 AM
bowdown201
Nov 19, 2008 04:55 PM
goldito187
Oct 30, 2003 11:18 AM
