compression ratio on stock internals?
Old May 22, 2002 | 12:05 PM
spankaveli's Avatar
Default compression ratio on stock internals?
i have to replace the piston rings and valve seats, so i'm gonna go ahead and replace the pistons to bump up the compression ratio. 11.3:1 would be had using USDM B16 pistons, whereas i could spend more money and get 10.8:1 with USDM B18C5 pistons. question is, is 11.3:1 too high to run daily? i know the timing will have to be turned back to stock, plus i already run 93 octane anyway. any downsides to this? any input would be appreciated.
Old May 22, 2002 | 12:17 PM
customx_'s Avatar
New User
Default Re: compression ratio on stock internals? (spankaveli)
http://www.c-speedracing.com/howto/c.../compcalc.html
Old May 22, 2002 | 12:23 PM
spankaveli's Avatar
Default Re: compression ratio on stock internals? (mindtrix)
thanks, but thats the link i used to determine what the CR would be w/ the b16 pistons. now i just need to know if its too high to run on stock internals. thanks....
Old May 22, 2002 | 12:26 PM
customx_'s Avatar
New User
anything from 11.1 to 12.1 CR is fine to run daily on 93 octane
[Modified by mindtrix, 1:26 PM 5/22/2002]
Old May 22, 2002 | 09:50 PM
spankaveli's Avatar
123Four
Aug 14, 2007 07:01 AM
killerpenguin21
15
Jul 9, 2006 09:53 PM
Maxboost00
Oct 1, 2004 10:42 PM
spankaveli
May 23, 2002 12:46 AM
Chuji
Oct 30, 2001 07:26 PM
