Comparison of B20 and B16 AC Compressor Engine Mounts....
Old Aug 25, 2002 | 08:11 PM
boomslang's Avatar
Default Comparison of B20 and B16 AC Compressor Engine Mounts....
Going from what I was told on this board, I bought a DOHC VTEC Del Sol AC mount so I could have AC with my B20 swap. After closer inspection of the Del Sol mount, I thought it looked alot like the stock B20b AC mount I already had.
I went and dug the B20 mount out of my parts pile.
Here are pics. Brand new Del Sol on the left, used B20b on the right.
The caliper is held open 1" for scale. As you can see, the mounting holes to the block and AC compressor are identical on both mounts. I set the mounts on top of each other in this next pic and put pins in the AC mounting holes. They line up perfectly.
The bolt hole spacing and pattern is identical on both mounts. The castings are different, but for all practical purposes, the mounts are interchangeable.
Old Aug 25, 2002 | 08:22 PM
Malachi's Avatar
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (Inlinefour)
what year delsol is the mount for?
Old Aug 25, 2002 | 10:35 PM
hondaZvic's Avatar
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (Malachi)
hmm.. very interesting.
Old Aug 26, 2002 | 12:15 AM
Kamin's Avatar
does it matter?
there all the same (except the 400 96 del sols with obdII b16a2's)
Old Aug 26, 2002 | 05:03 AM
boomslang's Avatar
The Del Sol mount in the picture was for a '95 model. It has P54 cast into.
The CRV mount is from a '97 auto, USDM.
Old Aug 26, 2002 | 05:27 AM
SuperCivic's Avatar
heh..anyone wanna buy my old b20 A/C bracket now?
Old Aug 26, 2002 | 06:57 AM
Malachi's Avatar
the ac fits with the del sol mount and not the b20, despite that they line up?
Old Aug 26, 2002 | 07:16 AM
boomslang's Avatar
No. It will fit with either mount. Using the stock B20 mount will save you from buying a $110 Del Sol mount.
Just for clarification, this is for putting a B-series engine in a 92-95 Civic, using the stock Civic AC compressor.
I don't know if it applies to 96+ Civics or not.
Old Aug 26, 2002 | 07:19 AM
Malachi's Avatar
cool, thanks.
Old Aug 26, 2002 | 07:21 AM
SuperCivic's Avatar
Great Info!!!
Old Aug 26, 2002 | 10:41 AM
Mr.Hatch's Avatar
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (SuperCivic)
Iv'e just gone through basically this same problem. I ordered the ac bracket from a 96 Del Sol VTEC. It has the same part number as the 99-00 Civic Si - stamped P30. But it is identical to the bracket that came on my B18C R - stamped P73 and the bracket from a friends B18C1 - stamped P72. So it looks like the 95 Del Sol is indeed the one you need.
Old Aug 26, 2002 | 01:45 PM
Trey's Avatar
25 Year Member
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (Mr.Hatch)
I ordered the 99-00 Si mount and it has the P54 in the part number.
Works like a champ.
P30 one is from a 94-95 del Sol DOHC Vtec motor.
Old Aug 26, 2002 | 03:34 PM
boomslang's Avatar
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (Trey)
P54 is the Del Sol dohc vtec.
Old Aug 26, 2002 | 06:16 PM
b20guy's Avatar
I've been told by a couple people who did B20 into EK swap that the b20 would work. That's why I haven't bought the del sol one.
Old Sep 4, 2002 | 01:52 PM
jaysonx's Avatar
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (b20guy)
Well, im getting a b20 A/C bracket for my swap (b20z into delSol). I found one cheap so im going to try it out. Just hope it fits...
Old Sep 5, 2002 | 05:08 AM
boomslang's Avatar
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (jaysonx)
B20b works, B20z should too.
[Modified by Inlinefour, 8:09 AM 9/5/2002]
Old Sep 5, 2002 | 09:30 AM
irev210's Avatar
what about PR3 a/c bracket, the holes also seem to be the same
can anyone confirm this?
Old Mar 5, 2003 | 07:30 AM
Cuong-nutz's Avatar
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (irev210)
bringing something useful back from the dead since the search function isn't all that great!
Old Mar 5, 2003 | 08:54 AM
Newman's Avatar
New User
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (boomslang)
Of course, because the CRV engine bay chassis is the same as an EK Civic engine bay chassis (similar to an EG Civic engine bay and a DC Integra engine bay.... same layout & size). There's a B-series motor in the CRV so if you put a B-series motor into an EK Civic, you would use the same AC braket
Old Mar 20, 2003 | 06:41 AM
DevinW's Avatar
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (Newman)
"because the CRV engine bay chassis is the same as an EK Civic engine bay chassis.. "
Because I remebered the above statement when I was doing my swap, we tried using the stock B20Z timing belt mount bracket, instead of the 99-00 Si(R) one..and it worked like a charm! We compared the 2 are they are almost identical...this is only for B20s into 96-00 Civics I believe tho.
That saved me almost $100 Canadian... Thanks Newman!
Old Mar 23, 2003 | 01:18 AM
VitaminB20's Avatar
From: Where the grass is green and the girls are pretty.
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (DevinW)
Wtf? My B20 AC bracket is a bulk of silver metal. It looks nothing like that.
Old Mar 23, 2003 | 01:33 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (VitaminB20)
Yeah! Guess im keepin the A/C!
thanks for looking into this
Blaze
Old Mar 26, 2003 | 08:14 PM
bzyrice's Avatar
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (Blaze45)
damn!! I wasted 100.00 bucks too.. hhe.. now i'm gonna look for the other a/c bracket and sell it haha.. .thanks for the info..
Old Apr 6, 2003 | 05:38 PM
b20guy's Avatar
Default Re: Comparison of B20 and B16 AC Compressor Engine Mounts.... (bzyrice)
just installed the b20, the b20 a/c bracket works GREAT.
Old Oct 7, 2003 | 10:36 PM
wm5holla's Avatar
what is p30 ac mount from? what will it work with? will it bolt up on a b18a in a eg hatch???
