cold air intake question
Old Sep 12, 2005 | 10:52 AM
jadsi420's Avatar
Default cold air intake question
swapping a 2000 jdm itr into a 99 civic si. i need a cold air intake and it looks like i will have to get one for a del sol in order to fit properly. Is this the case? tia
Old Sep 12, 2005 | 07:43 PM
TrackSpeedRacing's Avatar
Default Re: cold air intake question (jadsi420)
Get a Integra Type-R 3"cold air intake system (ex: AEM, INJEN)
Old Sep 15, 2005 | 10:57 AM
SOHC_DK.'s Avatar
Default Re: cold air intake question (TrackSpeedRacing)
I just tried to fit a AEM cai (ITR model) into my EG with ITR swap, ... and it just did not fit.. ?? is it because of the aircon ???
Old Sep 15, 2005 | 02:33 PM
jadsi420's Avatar
Default Re: cold air intake question (SOHC_DK.)
i think i am going to go with the del sol short thanks.
Old Sep 15, 2005 | 02:34 PM
jadsi420's Avatar
i forgot but aem does make a hybrid intake that fits this exact swap. the only problem is that it isn't smog legal in california, where im from. Maybe you can find one for your swap.
Old Sep 15, 2005 | 06:05 PM
JeffBro's Avatar
AN Si intake doesnt fit in there? You could prob just use a ITR short ram cause I think it just bolts to the engine. Also I was thinking maybe you could get a injen short ram for a itr and then get a extension for a civic Si maybe...
I dunno I will be keeping an eye on this thread cause I am in the same boat with my B18c swap in my 96 civic. I am just using a modified stock arm with the stock airbox which is very restrictive.
Old Sep 15, 2005 | 10:47 PM
jadsi420's Avatar
Default Re: cold air intake question (JeffBro)
One other concern i have is that i hear if you go to a BAR referee that they won't pass your car unless the intake matches the motor. For some reason they take the time to look up the carb code and check if it goes with the motor. I think if i can't get my car to pass regular smog checks then i will take it to the referee with the stock intake (which i still don't have) and afterwards maybe put the hybrid model on and run that. the hybrid model is a long ram and should give the best performance. i can't believe it has been so hard to find the right intake. I already tried the gsr intake (long ram) and that doesn't fit.
Old Sep 15, 2005 | 10:48 PM
jadsi420's Avatar
there isn't an itr short ram.
Old Sep 16, 2005 | 08:07 PM
JeffBro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadsi420 &raquo;</TD></TR><TR><TD CLASS="quote">there isn't an itr short ram.</TD></TR></TABLE>
Thats what I was thinking myself but it wont pass Bar. at least if you have a gsr swap w/ skunk2. I am thinking the best route for passing Bar is to get a stock Si arm and use the stock air box.
thrasher373
Feb 17, 2008 02:10 PM
civic_66
Nov 19, 2006 05:54 PM
mythos666
Oct 25, 2006 02:40 PM
DeeBo
Dec 6, 2004 05:54 PM
jonnybravo
Mar 13, 2002 04:36 PM
