Code P1381
Old Jun 21, 2021 | 10:30 AM
Jace Johnson's Avatar
Default Code P1381
Hello I am working on a 1999 Civic with a second generation b16a. After doing a distributor seal replacement I have code P1381 showing up. While doing the cleanup of the distributor I took off all the electrical connections I could find and generally cleaned up all the oil vapor and corrosion. I didn't have the code before so I think I might've messed with a connection. Where should I start in diagnosis? thanks
Diagnosing the ignition coil I am not getting any resistance between the positive and the spring connection and the neg and the spring connection.
louevilhatch
Jul 15, 2007 12:20 PM
kamakaze1
Jul 28, 2006 11:06 AM
mugenbattle
Dec 13, 2003 06:12 PM
GuyInASpeedo
Sep 25, 2003 07:05 PM
