code 8 on h22a swap. tdc position
Old Mar 8, 2010 | 09:30 PM
edr090290's Avatar
Default code 8 on h22a swap. tdc position
hi there. where is the tdc position sensor on a 94 h22a vtec. i have checked the timing 4 times and its all good. it bogs down when you give it gas and if you advance the timing it idles at 2.5k. it has almost no power. i was just wondering if the tcd position sensor is in the distributor or where its at so i can replace it.
Old Mar 9, 2010 | 03:53 AM
perseverance's Avatar
Default Re: code 8 on h22a swap. tdc position
it usually only looks for that in obd2, if not then it's referrence to the sensor in your distributor. looks up the ecu pinout and check continuity between the ecu and the dizzy. i've had to run new wires from the ecu to the dizzy once before for the same problem. it's cheaper than replacing a dizzy. but if u dizzy is bad, well big money.
EpochZ
Feb 4, 2019 04:30 AM
fanaticalK
Jul 16, 2009 06:58 PM
asmallsol
Aug 14, 2006 12:44 PM
wickedxboi
Oct 28, 2003 08:12 PM
hungy
Mar 30, 2003 08:30 AM
