Code 43 help
Old Aug 5, 2004 | 04:48 AM
delSolLS's Avatar
Default Code 43 help
Did a search, hope someone can help me out. Hav a built 95 B18B in my 93 del Sol. Primarily when I'm driving on the highway for 40-50 miles, I am getting a CEL code 43.
O2, MAP sensor test good, fuel pressure is at 43psi and goes up when removing vaccuum hose from FPR.
When coming to a stop, idle goes way down, sometimes stalling and then hunts until it settles in around 700 rpm. Have a HKS Super AFR piggy back computer to help take fuel out at idle for the Crower 404 cams (non VTEC).
Fuel injectors seem to be working fine. Could it be a fuel pump going out? Intermittant bad FPR?
Any ideas would be aprreciated.
Old Aug 5, 2004 | 11:10 AM
delSolLS's Avatar
Default Re: Code 43 help (delSolLS)
Replaced FPR- no change. O2 sensor is less than 1 year old. Has new IACV, MAP sensors. TPS sensor checks out. Fuel pressure is 41 psi at idle, 44 psi with vaccuum disconnected.
Removed A/F meter and soldered O2 sensor connection at computer.
Any other suggestions?
Dan_si_ej8
Engine Management and Tuning
Jul 8, 2017 10:18 AM
triple5soul8781
Aug 24, 2008 06:24 AM
delSolLS
Jul 8, 2003 11:03 AM
specie
Jun 2, 2003 04:08 PM
SoPoCivic93
Sep 26, 2002 02:20 PM
