code 14
Old Nov 30, 2002 | 05:24 PM
kwil666's Avatar
Default code 14
ok guys help me out, i just replaced my head on my 94 GSR engine, its in a 93 civic SI. everything seems to be hooked up and working. but im getting a code 14. which is the IAC, i have tried two other ones that i think were good and it still gives me the code 14. today i tried a brand new IAC i ordered from honda and i tried it but it gave me the same code. i have reset the ECU many times with no luck. im pretty sure its not the wires because when i start the car and unplug the plug going to the IAC the idle drops like its suppost to, so i figure the wires are good.
my next problem is that i need to set the timing so i can at lease drive it home (its sitting in front of a friends house) but i cant set the timing until the idle is good. so i guess that brings me to my next question. I think the IAC only controls the idle when the engine is cold so what if let it warm up until the idle is at 900 and then set the timing. i know i need to set the timing when its warm anyhow but just though i should check to see if the IAC plays any roles after the engine is warmed up. well thanks in advance for any info you guys can give me.
keith
Old Dec 1, 2002 | 10:49 AM
kwil666's Avatar
Default Re: code 14 (kwil666)
ok i think i have it figured out i got the code 14 taken care off, but the idle is still messed up. when warming up it jumps between 1500-3000 but not like it did before. when warm it still sits near 1500 and goes between 1400-1700. i was talking to my friend last night and we figured out that i have let a lot of air into the coolant lines while replacing all these IAC so im figuring i just need to bleed the lines really good. anybody have any other ideas?
keith
super jdm yo
Apr 12, 2012 11:04 AM
lexrob
Jan 4, 2010 09:16 PM
kwil666
Dec 14, 2002 11:58 PM
91CRXSI
Jul 16, 2002 07:42 PM
