code 10 ? please help
I am getting a code 10. IAT sensor code. I replaced it with another sensore and I am getting the same code. Is this the sensor thats on the top of the Gsr intake manifold ? also what the sensor thats located in the intake piping right after the filter ? My setup is a 99 gsr motor. 2000 si wiring harness with the obd2b-obd1 jumperharness with p28 w/s100b. any help will be greatly appreciated .
danny
danny
Which IAT sensor are you using? There are two available in your case: 1 the sir, the small black sensor on the intake tube or, 2 the gsr, the small black sensor on the very top of your gsr manifold.
When I do this swap I prefer to rewire the sir harness to plug in and use the gsr IAT sensor. If you decide to do this, you will need to get the proper plug with some wire leads for the gsr sensor and solder up the wires from the sir harness to it.
It may be a lot easier for you to try replacing the sir sensor in the intake tube if that is the one you are currently using. Good luck.
BoostnEK6206
Oct 18, 2007 10:53 AM
