Cluster problems ?????
Old May 1, 2013 | 10:04 AM
kenmar's Avatar
Default Cluster problems ?????
Hi recently replaced old engine, engine harness, dash harness and cluster to a B16a. problem tachometer, spedometer, temp gauge, fuel gauge, cel, high beam not working. All parts came from same donor car and were working fine. Tried another set of clocks exactly the same thing. Could it be a bad ground, if so witch one would it be ?. Any help appreciated.
Old May 18, 2013 | 11:27 AM
O'Grotton's Avatar
Default Re: Cluster problems ?????
Have you checked continuity on the grounds? Or for your power?
Old May 24, 2013 | 01:23 AM
kenmar's Avatar
Hi yes have continuity. getting 12v on fuse #15 and power to yellow wire at pin A3. Those are the one's I'v been told to check so far.
carlmel
Honda Civic (2001 - 2005)
May 11, 2026 08:57 AM
sleep_Rx
Nov 29, 2007 09:01 AM
litterbox
Mar 14, 2006 07:04 PM
NobodySpecial
Jan 7, 2005 11:22 AM
CMCivicSI
May 20, 2004 04:24 PM
