ckp sensor help........PLEASE!
Old Mar 17, 2004 | 07:41 AM
who00knows's Avatar
Default ckp sensor help........PLEASE!
I have a 97 b18c (jdm ITR ) in a 96 civic ex. To pass inspection in NC i have to use the stock ECU.....The jdm motor does not come with a ckp sensor but my ex ecu is calling for it........Anyone ran into this yet? I tried to bolt one on...but there is no bracket on the jdm oil pump.........Anyone seen a simulator or have anything worked out to get around this?
Old Mar 17, 2004 | 10:03 AM
Scott - 93HB Si's Avatar
Default Re: ckp sensor help........PLEASE! (who00knows)
that's not a CKP sensor, it's CKF (if you're talking about the oil pump magneto pickup)....
only thing I can think of is to change to a USDM OBD2 oil pump if you want to bolt that sensor on, unless you can find another way to mount it in the proper place - maybe make your own bracket to work on teh OBD1 oil pump....
Old Mar 17, 2004 | 11:37 AM
who00knows's Avatar
Default Re: ckp sensor help........PLEASE! (Scott - 93HB Si)
Its a ckp according the HONDA PGM-FI Program.......I was wondering another way besides that.
Old Mar 18, 2004 | 07:56 AM
EE_Chris's Avatar
The CKP (crank position) is located in the distributor. The CKF (crank fluctuation) is located on the oil pump.
If your getting the CKP code, replacing the dizzy sub-assembly is the only way to repair it (assuming the sensor really is bad).
If your getting the CKF code, you need a B-series oil pump that had this sensor (99 Si comes to mind).
There are no simulators available, nor work arounds for it.
potatointegra01
Feb 2, 2016 04:23 PM
existanzcivicb20
Mar 15, 2006 11:47 AM
warwagon
Jan 11, 2005 05:14 PM
4DRPIMPIN
15
Apr 23, 2004 05:46 PM
