CHECK ENGINE LIGHT ON BUT NO CODE....... SEARCHED
Old Sep 9, 2006 | 02:57 PM
kaoss_11's Avatar
B A N N E D
Default CHECK ENGINE LIGHT ON BUT NO CODE....... SEARCHED
I was throwing 3 codes and I fixed them all. The three were map sensor, tps sensor, and the iat sensor. Once they were all fixed the the check engine light came on 2 minutes later. I disconnected my battery and disconneted my ecu. So when I go to check my codes with the wire it doesnt flash or anything. The check engine light just stays. Any help appreciated I searched and no info related to my issue
motor is a obd 1 h22 running crome.
Old Sep 9, 2006 | 03:15 PM
vtec2nv's Avatar
Default Re: CHECK ENGINE LIGHT ON BUT NO CODE....... SEARCHED (kaoss_11)
i have heard when the check engine light just comes on when u jump it, usually means bad ecu. try unplugging everything again. then check the code again.
Old Sep 9, 2006 | 04:02 PM
kaoss_11's Avatar
B A N N E D
thanks
Old Sep 9, 2006 | 04:12 PM
turbociviccoupe's Avatar
Default Re: (kaoss_11)
we have that problem and it usually means a bad chip
Old Sep 9, 2006 | 04:44 PM
kaoss_11's Avatar
B A N N E D
I got to send my ecu back to mtber then
Old Sep 10, 2006 | 02:44 PM
vtec2nv's Avatar
Default Re: (turbociviccoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">we have that problem and it usually means a bad chip</TD></TR></TABLE>
or that 2
Old Sep 10, 2006 | 04:14 PM
kaoss_11's Avatar
B A N N E D
thanks
()0()Miklo
Oct 7, 2007 04:30 PM
kaoss_11
Sep 10, 2006 12:03 AM
ph0shizzle
May 13, 2006 08:36 PM
0-400DC2-R
Sep 28, 2003 11:48 AM
integrater
May 7, 2003 11:52 AM
