Check Engine Code......
Old Apr 10, 2002 | 05:35 PM
rca90gsx's Avatar
Default Check Engine Code......
Got the B16a running in the 92 hatch, throwing a #8 check engine code, wondering what causes for this TDC position to throw the code? Engine sounds great at idle, but when reved, it falls on its face, exhaust smells very very rich, which should be with the stock cx's injectors still in this engine. Chipped P28 ecu in the car now, any help is appreciated, also, where can i get a print off of the engine codes and possible causes??
Richie
Old Apr 10, 2002 | 10:53 PM
Jaker's Avatar
Default Re: Check Engine Code...... (rca90gsx)
Here's your engine codes:
http://hybrid.honda-perf.org/tech/codes.html
As to the TDC sensor, its in the distributor, and the engine does not know when the #1 piston is at top dead center, and is having difficulty firing the injectors at the correct time.
There is no fix for the problem if the sensor is really defective. You will need to replace the distributor. It could also be the wiring from the ECU to the sensor.
[Modified by Jaker, 11:54 PM 4/10/2002]
VTiSpec
Mar 9, 2014 12:33 AM
jdmspooner86
12
Sep 2, 2010 05:29 PM
EquipedWithVtec
Feb 13, 2008 05:20 PM
b18c1VX
Mar 20, 2003 10:09 PM
avs
Sep 22, 2002 02:00 PM
