CEL stays on
hey guys for some reason my CEL stays on. I do the reset procedure and it never goes away. I also can't pull DTC from it. it never goes out. if the key is on the cel is on. any ideas? its a 92 eg with a p28 ecu. The motor is a 94 ls/vtec.
Thanks
Thanks
When you jump the pin, be carefull not to insert the pin where the plastic tabs are. I had put my paper clip in there and I wasn't able to get the codes.
If you're check engine light is on, then you must have some sort of code.
dapek
Dec 1, 2008 09:38 PM
skUnK2jdm
26
Feb 7, 2008 10:08 AM
