CEL Code 8: TDC
Old Sep 16, 2005 | 10:29 AM
dawrenn's Avatar
Default CEL Code 8: TDC
I have a 99 Civic with a 99 GSR engine converted to OBD-1. The other day the CEL same on, It was code 8: TDC . I had the same code 3 weeks ago. The dizzy was replaced. My friend did some research and found out it could either be a wire under the dizzy cap between 2 screws or the wires for the plug that plugs to the dizzy could be bad. He said I should check the resistance between these to slots on the top of the plug. He said the resistance should be between 300 and 350. Does that sound right? What else could it be?
Old Sep 18, 2005 | 06:58 AM
dawrenn's Avatar
Default Re: CEL Code 8: TDC (dawrenn)
Bump^^^^
Old Sep 20, 2005 | 04:53 AM
Scoupe's Avatar
Bump>>
Got same problem overhere
Old Sep 29, 2005 | 04:45 PM
b18_crx's Avatar
Default Re: CEL Code 8: TDC (Scoupe)
friend has same problem anything
Old Sep 29, 2005 | 05:09 PM
phatrick2332's Avatar
Did you look in the helms to make sure those resistance numbers are correct, and then tested to see what they are on your car? Come back when you do.
Old Sep 29, 2005 | 10:29 PM
dawrenn's Avatar
Default Re: (phatrick2332)
IT was a disconnected wire from the ECU. I am having no problems now.
Old Oct 14, 2005 | 05:59 AM
underpressure02's Avatar
Default Re: (dawrenn)
Which wire color and ECU pin out was it? I am having the same problem and I am going to start looking at it tonight. I checked the helms late last night but figured I would work on that tonight. It only throws the code the first time I start the car in the morning.
B_Swapped93
Jun 14, 2013 12:41 PM
Lucky-13
21
Mar 22, 2007 05:27 AM
95_red_dc
Dec 23, 2006 12:54 PM
Dancing is Forbidden
Oct 17, 2003 05:43 AM
