CEL 43
Old Apr 16, 2003 | 01:11 PM
baonest1's Avatar
Default CEL 43
ok i got the check engine light after my car was idling for like 20 mins or so, the fans kicked on. so i check it and its a 43, malfunction fuel supply or somthing. i did a search and i found that i could be running rich.
well i have stock integra injectors with a 190 walbro pump. its a ls/vtec in a LS body. GSR wiring harness. any advice? perhaps change o2 sensor?
TIA
Old Apr 16, 2003 | 01:19 PM
poison's Avatar
Do you have an FPR or fuel gauge? With the 190 lph fuel pump, I would suggest investing in an FPR/pressure gauge to turn down the fuel pressure. Sounds like you're running very rich.
Also, check your spark plugs and see waht color they are.
Old Apr 16, 2003 | 04:50 PM
baonest1's Avatar
Default Re: (poison)
yah i have FPR and guage. well the light is off now. wierd how it came on. im running 48 psi with the hose off. i am going to lower it down to around 40 or so and see how it runs.
thanx for the help
Old Apr 16, 2003 | 05:03 PM
poison's Avatar
Default Re: (baonest)
hmm. with the hose off that is where I am as well, that's where I'm supposed to be though
keep this thread posted
tron-R
Sep 22, 2007 11:48 AM
Slain
Apr 18, 2007 12:06 AM
YoungKadafi
Apr 1, 2007 04:43 PM
hwnstyle21
Sep 9, 2002 07:27 AM
