camber on rear disc conversion.
Old Feb 10, 2004 | 10:44 AM
thad
Guest
Posts: n/a
Default camber on rear disc conversion.
i did a rear disc conversion on my 94 coupe a while back with brakes from a 92 ls, everything looks good. so a couple weeks back my friend got his rear discs from another DA integra, we put them on and it's got some negative camber, not a ridiculous amount but it's definately noticable. it may just be that i'm using coilovers and he's on cut stocks, but now i'm wondering if there is a differance between the upper control arms on the rear trailing assembly of civic and teg, or maybe between years.
Old Feb 11, 2004 | 03:48 PM
thad
Guest
Posts: n/a
Default Re: camber on rear disc conversion. (thad)
ttt
Old Feb 12, 2004 | 10:34 AM
JDMorgan's Avatar
i dont understand? why are you using da brakes on an eg? i thought you use da on an ef and dc on an eg? or is that only front that matters? i guess the rear bolt up since us da ppl use dc trailing arms and all. tell him to get some lowering shocks. no matter which arms u use it shouldnt give negative camber, did both of you guys use the da control arms too? i baught spc control arms for my da but they take alot of time to get the wheels where u want. i perfer a lil bit of negative camber. seems to help cornering.
EDIT: you could get a set of megans racing control arms which are ripoffs of spc ones for pretty cheap. lookup integra control arms on ebay.
Old Feb 13, 2004 | 09:36 AM
thad
Guest
Posts: n/a
Default Re: (KraZEtEggIE)
never mind
lorenzookc
Suspension & Brakes
Mar 14, 2010 04:47 PM
singlehx
Sep 12, 2009 09:04 PM
igo4bmx
14
Aug 5, 2004 01:20 PM
91SIR
Apr 22, 2003 01:56 PM
chhuong
Mar 21, 2002 12:04 AM
