Big Brake Kit (not a normal question)
I would like to know what is the largest brake rotor/caliper combo I can go with and still fit inside of a 13" wheel. I autox a lot and run 13's as my race tire.
Thanks.
Scott
Thanks.
Scott
I'd agree with the previous statement and add that the guys who are running the OEM 10.2" brakes & 13" wheels have only found two brands/models that fit so far. They are the Panasport C8 (13x8.5) and Lenzo VPD (13x7.5).
There are two DSP cometitors in the RR/AX forum that were/are using each of the previous setups. "Watkinsm3" and "Geratol" respectively. You can probably ask them if you need to know offset, etc.
accordselux
May 19, 2006 05:00 PM
