bad idle :(
Old Jan 31, 2008 | 09:24 PM
cadwiese's Avatar
Default bad idle :(
i have a 93 hb si with a 95 ls b18b1 in it
i am having a idle problem, it is idleing at 1500 rpms cold and/or warmed-up
pls help
Old Feb 4, 2008 | 04:21 PM
cadwiese's Avatar
Default Re: bad idle :( (cadwiese)
bump
Old Feb 4, 2008 | 05:51 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cadwiese &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 hb si with a 95 ls b18b1 in it
pls help</TD></TR></TABLE>are you using an OBD-I P75 ecu? Make sure all your vacuum lines are connected and that throttle body gasket is not torn. Trust me on the second part because it will cause an eratic fluctuation in idle.
Old Feb 6, 2008 | 10:35 PM
cadwiese's Avatar
i replace the iac and that didnt fix the problem so i am now going to look into the tb gasket
Old Feb 20, 2008 | 05:14 PM
cadwiese's Avatar
i replaced the t/b gasket and now i get a good idel but it is really low when it is warmed up it is idleing at 300 rpm pls help
Dwalker
Jan 13, 2008 12:13 PM
95dc2teg
Sep 11, 2007 05:49 PM
wedgenix
May 27, 2005 07:54 PM
neXus dc4
May 15, 2004 12:04 PM
SpoolnG2
Oct 17, 2002 09:49 PM
