b20vtec starting issues...help guys
Old Mar 17, 2004 | 05:31 PM
misfithamster's Avatar
Default b20vtec starting issues...help guys
ok guys, i have an 89 hatch that used to have a stock b16 in it with a mugen chipped ecu, i had the motor for about 5 months and only put about 3000 miles on it. it ran great never had any probs. so 2 weeks ago i went for the b20vtec conversions. everything went great and i was up and running but i only have one problem.. when i go to start the car from sittin over night or for a certain period of time, (over an hour or two) the car fires right up then instantly dies. when i go to start her the 2nd time it fires right up and everything is fine. drives fine, no leaks or anything. and this problem has been clock work for 2 weeks and i cant figure it out. first start dies, second start perfect.. i have a new water pump, timing belt, plugs, plug wires, cap, rotor, and a new fuel filter. i thought it might have helped, but no dice. the one thing i havent changed yet is the pump wich i have a 255 walbro comin. i was highly recommended this pump with the new motor compared to my original stock one. do you think this could be the problem? any experiences like this or suggestions would be greatly greatly appreciated. if you need any more info from me to help out, let me know. thanks guys.
Old Mar 17, 2004 | 07:56 PM
Default Re: b20vtec starting issues...help guys (misfithamster)
Old Mar 17, 2004 | 09:16 PM
SCsol's Avatar
sounds to me you have a problem with fuel pressure. Get a gauge and check the pressure drop. You must be bleading fuel with the car not on. One way to check this its to turn the key to the start postion for 10 sec. then start the car If it starts and keeps running then thats your problem. IM me back if that fixes it thanks
Old Mar 18, 2004 | 11:24 AM
Default Re: b20vtec starting issues...help guys (SCsol)
pm'd ya man, gonna try it out this afternoon...keep ya posted
forevermemorabl
27
Sep 20, 2013 07:43 PM
redss90
Nov 7, 2010 11:23 AM
andyboy
Mar 29, 2006 07:58 AM
lawlerlaw
Nov 16, 2004 01:25 AM
misfithamster
10
Mar 19, 2004 03:12 PM
