B20v compression help
Old May 10, 2016 | 08:58 AM
Crxdelaño's Avatar
Default B20v compression help
Currently building a b20v. Built b20b block, stock sleeves, block gaurd. Stock resurfaced pr3 head. I've calculated my CR to be at 9.7:1. I plan on boosting this setup but I need to sell the b16a currently in my car to get the funds so I wanna put the b20v in, run it with no boost while I sell the b16a. I figure it will serve as a break in period and I can tune out of boost. I know drive ability might be an issue with the low compression but will it be a total dog??? Any and all input/advice welcome.....even the people that are about bash me for doing this lol
Old May 11, 2016 | 07:04 AM
kp's Avatar
kp
Default Re: B20v compression help
No it won't be a dog, it's just shy of 10:1 which is fairly reasonable for any DD pump gas application. Keep in mind the factory spec B20B is 9.2/9.6:1 and not too many folks complain about that.
Dare I say you may just decide to leave it NA?
Old May 11, 2016 | 08:48 AM
Crxdelaño's Avatar
Thanks for the input kp. By "calculate" I mean I used an online compression calculator. Are those things accurate? The inputs were stroke, bore, comp height, how much milled off head, deck height, gasket and dome cc. And as far as leaving it NA, my goal is at least 200hp, with that being said, I don't think 9.7:1 will achieve that. Am I wrong?
1ls/vtec
Jul 25, 2009 04:03 PM
Toda Built
35
Sep 2, 2005 01:45 PM
99YZF
Jan 4, 2003 02:56 PM
evil_elmo
Jun 19, 2002 05:59 PM
