B20b4 HELP PLEASE!!!!
Old Sep 11, 2017 | 07:46 PM
dnxracer's Avatar
Default B20b4 HELP PLEASE!!!!
Okay guys so I swapped a b20b4 into my ek ran fine when pulled out of crv I pulled it out but now it doesn't on cold start up it'll start right ip and kinda stutter at idle but not bad well as soon as it's up to temp the motor just stalls and dies and won't run unless u give it throttle or I'll sit there a fluctuate like it's got a vac leak I've checked everything for vac leaks can't find a single one I'm running a ls intake with manual throttle body I can hear the iacv hum when keu is on before I start it there's no fitv on this motor it's in time and compression is good and I've replaced fuel filter and fuel pressure regulator I'm out of ideas oh yeah I'm also running a obd2b to obd1 jumper to a obd1 P75 any help would be appreciated thanks guys!
Old Sep 13, 2017 | 01:11 AM
dnxracer's Avatar
Default Re: B20b4 HELP PLEASE!!!!
Anyone??
Old Sep 13, 2017 | 04:39 AM
mk378's Avatar
If the harness is for a car originally having a 3 wire IACV you have to move wires in the OBDII ECU plug to make it work with 2 wire.
If that is the case you will have the IACV circuit code (14) thrown by your OBD1 ECU. Are any codes set?
Old Sep 13, 2017 | 07:53 AM
dnxracer's Avatar
I have no idea how to check if there is there's no cel on and I have already repinned ecu plug and converted the plug from 3 to 2 wire
Old Sep 13, 2017 | 07:55 AM
dnxracer's Avatar
And the iacv makes like a humming noise when car is running thru intake tube and if I shut car off and just have the key to on it will sit there and hum thru intake tube not running
Old Sep 13, 2017 | 04:38 PM
EsotericImage's Avatar
Retired Moderator
What ECU are you using
Old Sep 13, 2017 | 05:10 PM
dnxracer's Avatar
I have a obd2b to obd1 jumper with a obd1 p75
Old Sep 15, 2017 | 01:16 AM
dnxracer's Avatar
Bump
bseriesluver
10
Mar 22, 2011 09:11 PM
Unmexicano
10
Mar 21, 2011 08:19 PM
EJ1_Sleeper
Jun 28, 2009 08:48 PM
Rukusmasta2
Feb 8, 2008 12:53 PM
