B20b swap in ek hatch problems.
Old Apr 25, 2016 | 06:49 AM
Cfisch619's Avatar
Default B20b swap in ek hatch problems.
Hey, i just finished putting my b20b into my ek hatch, and i was having problems getting the motor to align properly. I got all the mounts mounted/bolted in and secured yet the motor is tilted downward on the crankshaft pulley area, I have innovative motor mounts on there and hopefully someone can help me figure it out. Please and thank you.
Old Apr 25, 2016 | 07:02 AM
oldschoolmaster's Avatar
Default Re: B20b swap in ek hatch problems.
Should have used oem mounts
Old Apr 25, 2016 | 07:04 AM
Cfisch619's Avatar
Heres a pic finally, is there any other reason why though? i mean i still have oem mounts just would rather use the stiffer ones
Old Apr 26, 2016 | 05:07 AM
tony_2018's Avatar
Fish Twig
Change that 2 bolt post driver side mount?
Old Apr 26, 2016 | 06:53 AM
Cfisch619's Avatar
Old Apr 26, 2016 | 09:30 PM
Cfisch619's Avatar
Old Apr 27, 2016 | 10:06 PM
Cfisch619's Avatar
Old Apr 28, 2016 | 07:24 PM
Cfisch619's Avatar
Will a civic si em1 mount fit? sorry phone wouldnt let me post
Old Apr 29, 2016 | 02:40 AM
HondaPartsHero's Avatar
Technical Hero
Old May 1, 2016 | 06:39 PM
Cfisch619's Avatar
Originally Posted by HondaPartsHero
the old timing belt mount wont work, it still will sit slanted. Should i use a civic si em1 post mount or an integra one?
Old May 1, 2016 | 10:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You MUST use the "99-00 Civic Si driver's side engine bracket. When you place one side by side with the original CRV/B20 bracket, the difference will be obvious. Assuming that your Innovative mount kit is correct and isn't contributing to your problem, then replacing the bracket as I and HondaPartsHero have stated will fix the problem. The factory Honda part number is 11910-P30-000 if you cannot find a used one.
Old May 2, 2016 | 06:22 PM
Cfisch619's Avatar
Thank you and hopefully its right, sounds logical since the em1's use a b series engine for ek chasis. but the picture clearly states for b18c5 engines only, and dosent say anything about all b series engines, just that specific one.
xxwolfsrainxx
Oct 9, 2012 08:50 AM
drtysohc
Nov 22, 2006 09:30 AM
error
Nov 5, 2004 10:52 AM
Snipes69
Nov 3, 2002 08:31 PM
