B20 vtec???
Old Mar 13, 2002 | 08:02 AM
Turbohatch's Avatar
New User
Default B20 vtec???
I know that the stock pistons hit the valves on a b16 head. Is there the same problem with the gsr head too?
Old Mar 13, 2002 | 09:56 AM
bojangs's Avatar
New User
Default Re: B20 vtec??? (Turbohatch)
well the valves on these two heads are the same size..
Old Mar 13, 2002 | 10:48 AM
daver's Avatar
Default Re: B20 vtec??? (bojangs)
Why do you figure that the valves will hit? crvtec.com says there IS clearance, even at more aggressive cam settings. To be safe, tho, the trick is to widen the piston valve relief indents to accommodate for the larger valve dia.
It does sound like there isn't a real problem unless you go crazy with cam timing, aggressive cams, head shaving, a thinner gasket or combos of these.
d
Old Mar 13, 2002 | 11:04 AM
bojangs's Avatar
New User
Default Re: B20 vtec??? (daver)
i believe at 4 degrees advanced on the intake cam there is piston-to-valve contact but anything under that is safe.. i've never actually done the clearance myself so i can't speak from experience.. i was merely saying the valves on the two heads were identical diameter so any problem with one will be present on the other..
[Modified by bojangs, 8:04 PM 3/13/2002]
Old Mar 13, 2002 | 08:10 PM
StorminMatt's Avatar
Just replace the pistons with good aftermarket units with adequate cutouts and you will not have a problem. Besides, you should not be running a CR-VTEC with stock pistons anyway.
Old Mar 15, 2002 | 05:29 AM
Project SSAP1's Avatar
Default Re: B20 vtec??? (StorminMatt)
exactly what he said!!!..stop tryin to cut cost cause its gonna fu u up in the long runn...get some nice je pistons..or probe racing pistons...
lzylst
Nov 15, 2014 04:26 AM
quick Dick
Mar 30, 2008 02:00 PM
BigBlockCRX
Apr 19, 2005 11:15 AM
lsvtec101
Dec 5, 2003 01:20 PM
Ri5e
Feb 13, 2002 07:03 AM
