B20 swap
Old Mar 24, 2006 | 08:50 AM
hondachris1994's Avatar
Default B20 swap
Ive got a b16 in a 94 hatch(OBD1) and im goin to do cr/vtec I was just wondering does it matter what yr B20b block I get...I would think it doesnt matter because no sensors hook up 2 the block,but can someone shed some light for me
Old Mar 24, 2006 | 09:27 AM
Luserkid's Avatar
Default Re: B20 swap (hondachris1994)
I think the B20Z (99 CRV) is the one to get because it was made with a little higher compression (9.8 or something). Someone correct me if im wrong.
Old Mar 24, 2006 | 10:51 AM
. a d a m's Avatar
Default Re: B20 swap (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I think the B20Z (99 CRV) is the one to get because it was made with a little higher compression (9.8 or something). Someone correct me if im wrong. </TD></TR></TABLE>
I'm 99.9% sure that is correct
Old Mar 24, 2006 | 12:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I think the B20Z (99 CRV) is the one to get because it was made with a little higher compression (9.8 or something). </TD></TR></TABLE>Im changing the pistons anyways so does it matter which B20b or z
Old Mar 24, 2006 | 01:10 PM
. a d a m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">Im changing the pistons anyways so does it matter which B20b or z</TD></TR></TABLE>
As far as I know the blocks are the same. So it shouldn't really matter.
Old Mar 24, 2006 | 03:17 PM
Gadget's Avatar
Default Re: B20 swap (Sh!ttyLS)
B20B-Z blocks are the same.. I believe the later model B20Z they basically used a LS head to bump compression..
All mounts and bolt holes are the same.. only real diff is you have to use the B20 T-Belt, and run the -6an line to the back of the head and plug the old oil passage on the bottom of the head..
I highly reccomend using P/N:ARP-208-4306 from http://www.summitracing.com when you build it.. Using the B16 bolts just don't feel or torque right and if you're not careful you'll pull the threads out of the block.. I've built several engines using these studs and it couldn't work any better..
Good luck on your 200HP B20 buildup..
Old Mar 24, 2006 | 03:58 PM
Default Re: B20 swap (Gadget)
so my motor mounts will work on either b20b or z no matter what yr the block is?
Old Mar 25, 2006 | 11:12 AM
Gadget's Avatar
Yep.. B-series is all the same.. you could cram any B16,B17,B18,B20 in there using the same mounts..
Old Mar 28, 2006 | 09:18 AM
JDM_CivicEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gadget &raquo;</TD></TR><TR><TD CLASS="quote">Yep.. B-series is all the same.. you could cram any B16,B17,B18,B20 in there using the same mounts.. </TD></TR></TABLE>
Not I don't think you are going to be able to use ur stock mounts...you would be better off using 94= Integra mounts...or buy a set from Hasport.com....the integra mounts are cheaper of course...
Old Apr 6, 2006 | 04:51 AM
ralphie14's Avatar
That is incorrect. A B16 driver's side mount is different from an LS mount. The studs sit at a slight angle while on the LS they do not have such an angle.
Old Apr 6, 2006 | 05:11 AM
existanzcivicb20's Avatar
well the only thing that changes from b20b to the b20z is the pistons thats why it has little higher compression but no one is going to keep those pistons if they wanna make some power.
honda1998
13
May 1, 2008 03:18 PM
civic_jdm16
May 2, 2007 03:56 PM
eg6ryder
Feb 6, 2006 11:59 AM
Carlo Gambino
10
Jun 22, 2004 04:39 AM
civic5483
May 13, 2004 03:38 PM
