B20 head on B18C block?
Will it bolt right on? What would be needed to make it work..new timing belt/head bolts? Or is that only needed when you run a VTEC head on a non-VTEC block?
A buddy of mine has a B18C1 block for sale and if I can use it..Im thinking of using it for a couple months while I rebuild the B20...then I can use the B18C1 oil pan, pickup and girdle on my B20.
use a gsr timing belt, move dowel pins in the head, and use a gsr headgasket
not sure about the oil hmmmmmmmmm..................
it would allready have the vtec oil hole blocked so nothing really with oil maybe block the engine block instead of the head so you dont spluge oil everywhere.
chacabaca
Jun 6, 2011 10:17 PM
SmoKez
21
Nov 28, 2008 08:45 PM
jdm96dc2
Nov 5, 2004 12:51 PM
