B20 cranks, but doesnt START?!?!?
Old Sep 19, 2005 | 07:52 AM
Frank_2.0L's Avatar
Default B20 cranks, but doesnt START?!?!?
Hey you guys i've just dropped in my b20vtec into my hatch over the weekend. when i went to start up the car alls it does is crank, but no spark to start it? anyone have any ideas what could be the problem?
Old Sep 19, 2005 | 07:55 AM
RudeBwaiSi's Avatar
Recheck all sensors make sure everything is connected where they supposed to be. Could also be the dizzy.
Old Sep 19, 2005 | 07:57 AM
Frank_2.0L's Avatar
Default Re: (RudeBwaiSi)
i have a couple plugs that dont even have anywhere to plug them into? im running the b20 in a 96 hatch w/ 97ex harness and for some reason the harness has extra plug-in's ....probably like 3 plugs at most or just 2?
Old Sep 19, 2005 | 10:17 AM
Frank_2.0L's Avatar
Default Re: (Frank_2.0L)
any1?
Old Sep 19, 2005 | 10:31 AM
92Jspec's Avatar
can you post pics of the extra plugs? where in the engine bay are they located?
Old Sep 19, 2005 | 10:42 AM
Frank_2.0L's Avatar
Default Re: (92Jspec)
i can get pics tomorrow...but i know i didnt have a plug for the crank angle sensor, theres 5th plug where you plug in your fuel injectors plugs, and theres one that comes outta the firewall that looks like it'll matchs the crankangle sensor but thats way too far from it! those are the only ones i can think of....but im sure theres 1 more maybe
Old Sep 19, 2005 | 03:51 PM
Frank_2.0L's Avatar
ttt
Old Sep 19, 2005 | 04:57 PM
hondaxsimike's Avatar
when you're using a harness from another motor/car sometimes wires have to be extended to reach. you said one plug fits the CAS, it just might fit. go ahead and cut it and see if it fits. if worse comes to worse you just have to splice it back together, no biggie right? lemme know how it goes.
Old Sep 19, 2005 | 05:14 PM
Frank_2.0L's Avatar
Default Re: (hondaxsimike)
yea true...i've also been told that another reason for my car not starting is because it could be throwing some CEL, preventing my ecu from firing the engine? but i have no idea how to check it on a obd2 car..obd1 i know theres a plug u can easily jump to see...any ideas?
Old Sep 19, 2005 | 05:25 PM
Frank_2.0L's Avatar
would it do any use converting my ecu to obd1 or will i have the same problem still w/ the cel?
Old Sep 19, 2005 | 08:58 PM
Frank_2.0L's Avatar
Old Sep 19, 2005 | 09:09 PM
JeffBro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frank_2.0L &raquo;</TD></TR><TR><TD CLASS="quote">yea true...i've also been told that another reason for my car not starting is because it could be throwing some CEL, preventing my ecu from firing the engine? but i have no idea how to check it on a obd2 car..obd1 i know theres a plug u can easily jump to see...any ideas?</TD></TR></TABLE>
Don't think so. The ecu doesnt just say "oh sorry were not gonna fire today". It could not be getting a good crank position sensor signal tho. So you say no spark? So I take it you took a plug wire off and looked to see if there was a spark when you turned it over? Anyways check your dizzy. could be anything from a bad ckp sensor to a bad coil. Also I dont think that something not hooked up short of the whole dizzy plug would cause the ecu to not fire the engine. Also check the ecu ground and make sure its hooked up.
Old Sep 19, 2005 | 09:17 PM
Frank_2.0L's Avatar
Default Re: (JeffBro)
pm'd
Old Sep 19, 2005 | 10:10 PM
vw eater's Avatar
pic's?
Old Sep 20, 2005 | 07:20 AM
Frank_2.0L's Avatar
Default Re: (vw eater)
pic's will be up later today...
Old Oct 2, 2005 | 08:25 PM
vw eater's Avatar
pics?
Old Oct 2, 2005 | 08:52 PM
SpoonEk253's Avatar
solved da problem!
Old Sep 11, 2021 | 06:32 PM
hondaboy203's Avatar
16 years later , and id love to know what you did that solved your problem. @SpoonEk253
e-g-6jdm
20
Jan 22, 2023 03:29 PM
dj-t
Jan 27, 2011 05:55 PM
FunStuff
Aug 1, 2007 03:15 AM
bluntman427
Mar 6, 2007 08:11 PM
b20integrapower
Oct 18, 2006 02:22 PM
