B18c5 Swap Problem
Old Dec 4, 2005 | 04:02 PM
Fiend's Avatar
Default B18c5 Swap Problem
I just swapped a 98 USDM R motor into a 92 Civic cx using a chipped P28. The problem I am experiencing is that sometimes during accelerationt here would be a hesitation. RPM would not climb nor does it drop then a second later it starts pulling again. Everything is stock on the car besides from the engine and ECU. There are no check engine lights and the motor came out of a running car. Any help will be grateful. Thanks in advance.
Old Dec 4, 2005 | 06:35 PM
92Jspec's Avatar
Default Re: B18c5 Swap Problem (Fiend)
check your dizzy cap and rotor also check your spark plugs and wires
Old Dec 4, 2005 | 07:21 PM
JeffBro's Avatar
check engine light?
Old Dec 5, 2005 | 01:52 PM
SprayinCX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fiend &raquo;</TD></TR><TR><TD CLASS="quote">There are no check engine lights and the motor came out of a running car. Any help will be grateful. Thanks in advance.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffBro &raquo;</TD></TR><TR><TD CLASS="quote">check engine light?</TD></TR></TABLE>
i should punch you in the face so you will read next time instead of blabbing off the first thing that comes to your little mind.
btw you should try what 92Jspec said. it sounds like it could use a real good tune up. then if it is not that then whoever chipped your ecu. have them look at the tune it could be in the igniton or the fuel maps.
Old Dec 5, 2005 | 08:03 PM
Fiend's Avatar
Default Re: B18c5 Swap Problem (SprayinCX)
The problem went away for now. I filled it to full tank and it just stopped hestitating. It revs to redline with no problem. The car itself was sitting for at least for 6 months before I purchased it. Will water in the full tank cause something like this?
Old Dec 6, 2005 | 10:09 AM
Supernatural's Avatar
gas is like soda....it gets flat if its old
Old Dec 6, 2005 | 06:09 PM
hellb0y's Avatar
Default Re: B18c5 Swap Problem (NATURAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NATURAL &raquo;</TD></TR><TR><TD CLASS="quote">gas is like soda....it gets flat if its old</TD></TR></TABLE>
Hey i learned somthing new...another non-wasted day!
alfiler
Feb 16, 2009 11:55 PM
93DA9
Jun 1, 2008 07:44 PM
Hatch Heaven
Jan 28, 2006 12:04 PM
93hondaboy
Dec 21, 2005 12:21 AM
im_the_teacher
36
Aug 11, 2003 10:14 PM
