B18C5 into 92 Integra
Old Dec 18, 2003 | 01:31 PM
cjames235's Avatar
Default B18C5 into 92 Integra
My friend wants to do this swap but as we were thinking about it, does the cable VSS plug into the R transmission or do you have to convert to the electronic VSS? He will be doing the cable to hydro conversion from Hasport also. Another thing is what ECU to use. Thanks for looking.
Old Dec 18, 2003 | 01:35 PM
slammed_93_hatch's Avatar
Default Re: B18C5 into 92 Integra (cjames235)
as far as the ecu goes you can just use a OBD0-->OBDII harness and the stock ITR ecu. or use a OBD0-->OBDI harness and get a p28 chipped
Old Dec 19, 2003 | 06:36 AM
(JON)'s Avatar
Default Re: B18C5 into 92 Integra (slammed_93_hatch)
to use the hydraulic tranny with the hasport kit you would need to custom fabricate a upper transmission mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">as far as the ecu goes you can just use a OBD0--&gt;OBDII harness and the stock ITR ecu. or use a OBD0--&gt;OBDI harness and get a p28 chipped</TD></TR></TABLE>
the 92 integras are already obd1. you dont need a conversion harness. you can run a p30, p61, a reprogrammed p28 or a reprogrammed p72.
Old Dec 20, 2003 | 03:26 PM
cjames235's Avatar
Default Re: B18C5 into 92 Integra (DaStyle)
What is the deal with the need of a custom transmission mount?
Old Dec 20, 2003 | 03:33 PM
Devlins 91LS's Avatar
Mounting for the hydraulic clutch needs to be made, none of which is on the stock g2 tranny.
Old Dec 20, 2003 | 04:19 PM
(JON)'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjames235 &raquo;</TD></TR><TR><TD CLASS="quote">What is the deal with the need of a custom transmission mount?</TD></TR></TABLE>
if you use the 90-93integra or the 94-2001 integra tranny mount with the hydraulic tranny it wont line up, you also cant use the one that hasport supplies for the kit because its for ef chassis and also wont line up. there for the need for a custom upper tranny mount is a must!
Old Dec 21, 2003 | 10:38 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaStyle &raquo;</TD></TR><TR><TD CLASS="quote">
if you use the 90-93integra or the 94-2001 integra tranny mount with the hydraulic tranny it wont line up, you also cant use the one that hasport supplies for the kit because its for ef chassis and also wont line up. there for the need for a custom upper tranny mount is a must! </TD></TR></TABLE>
wut the heck.....Hasport didn't make a hydro tranny mount kit for DA integra's yet ? lol...that's wack!
c'mon Styles...get yo' **** togetha!
Old Dec 21, 2003 | 11:59 AM
(JON)'s Avatar
Default Re: B18C5 into 92 Integra (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
c'mon Styles...get yo' **** togetha! </TD></TR></TABLE>
it what i was told when i called hasport directly. if i was misinformed and in turn gave misinformation then i apologize.
Old Dec 21, 2003 | 01:30 PM
Katman's Avatar
it what i was told when i called hasport directly. if i was misinformed and in turn gave misinformation then i apologize.</TD></TR></TABLE>
no no... I didn't know if they did or not, that's why i commented. I assumed they did though. I found out a little while ago they don't make this kit for the DA chassis....which is weaksauce!
The guy (Brian Styles) who actually makes/designs the billet mounts for Hasport, unexpectedly quit recently & moved to FL.....lol....weird
Old Dec 22, 2003 | 03:37 AM
Stunna BEN's Avatar
Don't call it a comeback
The guy (Brian Styles) who actually makes/designs the billet mounts for Hasport, unexpectedly quit recently & moved to FL.....lol....weird</TD></TR></TABLE>
Damn that does suck. Way to move outta town though "fishy thoughts"
The DA hydro tranny mounts would be a hit.
Wonk Unit
Feb 11, 2007 10:26 AM
4thgenx42
Jan 4, 2007 05:34 AM
Danethomp
Apr 22, 2004 06:52 PM
JDMProjektSi
Feb 19, 2004 08:34 AM
ElectronMan
Jun 14, 2002 06:49 PM
