b18c1 wiring?
Old May 2, 2012 | 06:51 PM
TerrenceDinesen's Avatar
Default b18c1 wiring?
just taking a look at this faq https://honda-tech.com/forums/hybrid-engine-swaps-18/complete-obd1-b18c1-into-civic-vx-wiring-instructions-644434/ it shows the wiring of a 95 usdm gsr into a 94 vx for obd1. my question is, is it the same for wiring a 94 gsr b18c1 into a 95 ex (not a si) if not what are the exact wiring updates to make the car compatible to the engine
Old May 2, 2012 | 07:05 PM
untitled001's Avatar
Default Re: b18c1 wiring?
Vtec should be wired already if you have an ex
Old May 3, 2012 | 09:09 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
You don't have to worry about the O2 wire because you should already have the 4 wire O2 sensor. Your vtec wires are already ran. You do need to run knock sensor if using a p72 ecu so that link will help you with that and IAB's if your using stock IM.
I just put a 98 gsr in my 94 vx so I only had to repin those two wires in the link and the rest was a drop in deal. I also used a skunk2 pro IM since it came with my swap.
Old May 8, 2012 | 05:41 PM
face palm moment sorry guys my car is not a ex its a dx so besides running vtec solenoid/pressure switch all i need to do is wire the iab, and knock sensor ? also using a p72 ecu
Old May 8, 2012 | 07:08 PM
Lord Helmet's Avatar
yes sir that's it.
gnccracer20
Mar 23, 2009 03:23 AM
oneslowsohc
Feb 15, 2005 09:35 AM
integmester
Jul 22, 2004 04:26 AM
FwdCivicHatch
Apr 20, 2004 04:32 PM
NIGHTCRAWLER94
Apr 11, 2004 04:53 PM
