B18c1 block
Old Aug 25, 2016 | 09:52 AM
mikewhomiko's Avatar
Default B18c1 block
Hello guys. My ek hatch originally had a full b16 swap, I just swapped the block to a gsr b18c1 block. After a long swap. I went to test drive car and it won't pass 6900rpms. Anyone know why? I'm reading some say I need to chip ecu and some say I don't need to chip ecu. I'm using same b16ecu
Old Sep 2, 2016 | 05:52 PM
slomofo's Avatar
GDD Member
Default Re: B18c1 block
PR3 or P72 head? If you used the PR3 head, what timing belt/water pump did you use? Is your timing belt on perfectly and not one tooth off?
Btil253
Jun 2, 2015 02:34 AM
young geezer
Jun 26, 2009 01:16 PM
ricanem1
Jan 23, 2007 04:00 PM
turbocrx805
Jan 2, 2005 01:06 PM
Nextelbuddy
Jun 11, 2003 07:51 PM
