B18c secondary runner question
Old Sep 8, 2003 | 05:51 PM
oneslodx's Avatar
Default B18c secondary runner question
ok well ive had my B18c swap done for a couple months now and took it to a local mechanic a while back to get a ball joint checked out and he said my secondary intake runner isnt wired up? he said it would cause a lil bit of a lack in low end power. im just wondering wat has to be wired for it? i know it has the vacuum hose but is there actually a wire or plug that i have to wire to the ecu? also what exactly does that thing do?
Old Sep 9, 2003 | 01:11 PM
oneslodx's Avatar
Default Re: B18c secondary runner question (oneslodx)
bump
Old Sep 9, 2003 | 05:44 PM
Cynical 1's Avatar
Yup, has to be connected to a 12V power source, and wired to the ECU at the correct PIN.
Try searching the board. Lots of results and how-to.
Old Sep 9, 2003 | 05:52 PM
2lua's Avatar
there is a vacuum tank with a solenoid underneat the intake manifold with male plug at the sencondary intake it need to wire to a17 at the ecu and other wire go to ground.
Old Sep 9, 2003 | 05:55 PM
oneslodx's Avatar
Default Re: B18c secondary runner question (2lua)
ok so the plug i have on there from the stock harness is just not goin into the right pin? and i need to hard wire it to the right pin in the ecu?
danteisme
Audio / Security / Video
Sep 29, 2016 04:33 AM
DelSolMarine
Sep 9, 2006 05:32 PM
Monkey Fing a Coconut
May 28, 2005 06:58 PM
SAVIOVEGA
Sep 1, 2004 02:37 PM
