B18C into a CRX..... Simple Question??
Old Sep 13, 2003 | 03:19 PM
dohcdelsol's Avatar
Default B18C into a CRX..... Simple Question??
I am plannig on swapping a gsr engine into a 1990 CRX and i want to find out exactly what i need so when i do the swap i have everything and dont have to order and wait for it to come.
It;s a 1990 CRX
I m planning on ordering it from HMO, http://www.hmotorsonline.com/s...30009
The car already has exhaust, intake, and sport springs.
Also have Motor Mounts for any B-series engine
Shift linkage but im not sure if it would fit
Steel brake lines
I have someone to do the swap but i was told that i need to get a cable to hydraulic tranny conversion. Is this true?
What obd do i need, 0 or 1. i was told one.
Any imput would be awesome. Im still new to the whole engine swappage thing so i might be posting again here soon. thanks guys
Old Sep 13, 2003 | 06:37 PM
dohcdelsol's Avatar
Default Re: B18C into a CRX..... Simple Question?? (dohcdelsol)
Bump, i need the info
Old Sep 13, 2003 | 07:26 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">B18C into a CRX..... Simple Question??</TD></TR></TABLE>
https://honda-tech.com/zerosearch..... Simple Answer
Old Sep 14, 2003 | 07:31 AM
HT Chaplain's Avatar
Loved
Have HMO send you a cable tranny instead its easier and your swap will be cheaper.
Old Sep 14, 2003 | 07:34 AM
Loved
Default Re: B18C into a CRX..... Simple Question?? (legutki)
you can also switch out you injectors and dist for obd 0 b16 ones and everthing will plug in with your stock harness. And the money you save with buying a cable trans. instead of a hydo one buy a skunk2 IM so you dont have to worry about the IAB's and also get a pr3 ecu= easy swap plug and play just wire vtec
Loved
only if it is a hf or si though
Old Sep 14, 2003 | 08:10 AM
TotalJDM.com's Avatar
My friend has this setup, and for an N/A car I say it's definately worth it. It pulls very nicely!
Andre
AZWildchild
May 6, 2007 05:44 PM
zexhuffer
Feb 4, 2006 09:49 AM
Initial Kei
Mar 21, 2002 05:03 PM
