B18C in EK mount question
Old Apr 2, 2002 | 10:18 AM
Mucackus's Avatar
Default B18C in EK mount question
Im about to install a B18C into a 99 EK. What motor mount do I use on the drivers side(the one that bolts right beneath the cam gears). Can the mount from the D-series motor be used?
[Modified by Mucackus, 7:24 PM 4/2/2002]
Old Apr 2, 2002 | 10:24 AM
kenji's Avatar
25 Year Member
Default Re: B18C in EK mount question (Mucackus)
Get the cast metal mount/bracket that bolts to the side of the block from a '99-'00 Civic Si. I am referring to the one that is held on to the side of the block by (3) 14mm head bolts on the driver side. Use the stamped metal bracket that came with your car to attach the motor to the hydraulic body mount.
-kenji
Old Apr 2, 2002 | 11:58 AM
Trey's Avatar
25 Year Member
Default Re: B18C in EK mount question (kenji)
more info here:
http://www.jspectuning.com/6gen/
Old Apr 2, 2002 | 12:00 PM
Mucackus's Avatar
Is there something wrong with using the stock mount from my d-series block? will it not bolt up?? I read on the hybrid board that it could be used.
[Modified by Mucackus, 9:19 PM 4/2/2002]
Old Apr 2, 2002 | 05:47 PM
GokuSSJ4's Avatar
i use the one the swap provided with ,which happen to be integra!
Old Apr 3, 2002 | 08:53 AM
Mucackus's Avatar
Default Re: B18C in EK mount question (Spoon1)
How did you get the integra one too work?
Old Apr 3, 2002 | 12:06 PM
bigblockEG's Avatar
I used the integra mount and bracket as well. I have a eg though. Dont know if that matters.
Old Apr 3, 2002 | 06:44 PM
Trey's Avatar
25 Year Member
Default Re: B18C in EK mount question (bigblockEG)
EG can use the teg stuff, EK needs the 99-00 Si bracket (under the cam gears) and stock upper mount.
Pictures listed on the link I supplied above. Why all the questions? Don't be cheap and rig it up. Do it right.....
Also, D stuff won't work.......
Old Apr 3, 2002 | 11:11 PM
Mucackus's Avatar
Default Re: B18C in EK mount question (Trey)
thanks..already decided to go with the si mount...
lscoupe
Apr 24, 2005 11:15 PM
92eg6
Jun 7, 2004 08:41 AM
vsmEK
13
Apr 13, 2004 02:31 PM
ASHY-ELBOW
Jun 17, 2003 03:58 AM
b20ek
Jun 5, 2003 10:02 PM
