B18c dizzy,alt,positive ground problem??
Old Apr 19, 2003 | 05:02 PM
IS3Fifty's Avatar
Default B18c dizzy,alt,positive ground problem??
Ive had my b18c installed for a while, and just tried to turn it today... the starter kicks in, but for some reason I cant get the motor fully turned over. Now it cant be the dizzy, because we took it apart and tested the continuity and there was no problem between the ignitor and the coil ( no test light when touching the ignitor to the coil and cranking). So we looked at the alt, now there shouldnt be coming from there but going into the alt. Though there is.... somehow I have a positive charge in my block. I have 2 grounds 1. to the valve cover and 2. to the tranny. where are my other ground supposed to be?? isnt there one on the block under the IM??? Where the hell am I getting my positive power to my block from???
Old Apr 19, 2003 | 06:58 PM
trbob16a's Avatar
Default Re: B18c dizzy,alt,positive ground problem?? (purek9hybrid)
there is a ground that will ground on the passenger side of the engine bay. it comes from the engine wiring harness and splits like a little fork, it bolts in right after where your heater water outlet is over under the distributor
Old Apr 19, 2003 | 09:20 PM
IS3Fifty's Avatar
Default Re: B18c dizzy,alt,positive ground problem?? (trbob16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trbob16a &raquo;</TD></TR><TR><TD CLASS="quote">there is a ground that will ground on the passenger side of the engine bay. it comes from the engine wiring harness and splits like a little fork, it bolts in right after where your heater water outlet is over under the distributor</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> have 2 grounds 1. to the valve cover and 2. to the tranny</TD></TR></TABLE>
Old Apr 20, 2003 | 08:48 AM
IS3Fifty's Avatar
no one knows.... wheres poison,villian, voodoo, and Emerica when you need them....
Old Apr 20, 2003 | 08:59 PM
IS3Fifty's Avatar
bump
Old Apr 21, 2003 | 09:00 AM
IS3Fifty's Avatar
to the top for spade.
Old Apr 21, 2003 | 09:09 AM
Spade's Avatar
Do you have a power steering or a/c ground?
Old Apr 21, 2003 | 09:13 AM
IS3Fifty's Avatar
Default Re: B18c dizzy,alt,positive ground problem?? (Spade)
took them out spade... it went into the Cx so no need to do all the power steering garbage and I dont care about Ac at the time.
Old Apr 21, 2003 | 09:18 AM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purek9hybrid &raquo;</TD></TR><TR><TD CLASS="quote">took them out spade... it went into the Cx so no need to do all the power steering garbage and I dont care about Ac at the time.</TD></TR></TABLE>
Kewl, how about where the valve cover ground is?
Does it look like this?
Old Apr 21, 2003 | 09:20 AM
IS3Fifty's Avatar
yep... try again.. I have all the grounds. Wiring and everything done. Im thinking maybe vac seal leak between the IM and TB???
Old Apr 21, 2003 | 09:22 AM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purek9hybrid &raquo;</TD></TR><TR><TD CLASS="quote">yep... try again.. I have all the grounds. Wiring and everything done. Im thinking maybe vac seal leak between the IM and TB???</TD></TR></TABLE>
Possible. But the seal leak would create a higher rev.
Old Apr 21, 2003 | 09:25 AM
IS3Fifty's Avatar
well I dont have a throttle cable hooked up so I cant rev unless I do it by hand. I am using my stock CX ecu to start the car but it should idle with that computer. my comp hasnt come yet.
Old Apr 21, 2003 | 09:27 AM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purek9hybrid &raquo;</TD></TR><TR><TD CLASS="quote">well I dont have a throttle cable hooked up so I cant rev unless I do it by hand. I am using my stock CX ecu to start the car but it should idle with that computer. my comp hasnt come yet.</TD></TR></TABLE>
I'd hold off on trouble shooting until you get an ECU capable for that engine. Theoritically, the CX ecu should be fine, however you may damage something by running too lean or some of you sensor are in the wrong locations.
Old Apr 21, 2003 | 09:31 AM
IS3Fifty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">
i was thinking about that, but I wasn't sure whether that would have a bearing or not. I talked to Marcus from HeelToe, he told me if should be fine to start on but he wouldnt run it anywhere with that ecu. I felt the same way. Technically, all Honda idle is the same right??? so I cant see why it would do that.
Old Apr 21, 2003 | 10:02 AM
Spade's Avatar
Technically but, you are using an ECU made for a much smaller engine.
Plus the wiring could be different.
What generation ECU/engine?
Old Apr 21, 2003 | 02:05 PM
IS3Fifty's Avatar
obd1 to obd1
Old Apr 21, 2003 | 04:40 PM
trbob16a's Avatar
I told you, there should be a ground that comes out of the wiring harness and grounds around below your distributor/water outlet area... check your helms its there, are you sure you grounded it?
Old Apr 21, 2003 | 06:47 PM
IS3Fifty's Avatar
dude... yes get off that subject. Im not a moron. That was the first ground that was made.
Old Apr 22, 2003 | 03:06 AM
trbob16a's Avatar
That is what you said. Then you said you have a positive charge on the block. There are three grounds, not two. From what you keep typing you only have two hooked up which would explain your positive charge. If you have all three hooked up you should have made that clear and not said you have 1) to valve cover and 2) to tranny.
Old Apr 22, 2003 | 04:56 AM
IS3Fifty's Avatar
if you read the whole post you would see that this issue was already cleared up.
Old Apr 22, 2003 | 09:19 PM
IS3Fifty's Avatar
Default Re: B18c dizzy,alt,positive ground problem?? (TODAeg6)
Well... now Ive tried a LS ecu and I still can not get the thing to start and idle on its own. There are large "cracks" when attempting to start the motor, as i said before fuel is correct. Im beginning to believe its timing now. Any opinions??
Old Apr 24, 2003 | 06:56 AM
IS3Fifty's Avatar
im starting to think that there is a problem with either A. the wiring to the injectors or B. the timing. Anyone have any incite?? The motor will start on a cx computer, but would not start with an LS. I am waiting on my GSR comp to get here. It cracks extremely loud, though it is open header. Once I have tried to start the motor a few times, I shut it down and hear a gurgling sound. Intake?? or is that exhaust??
uzi boy
Engine Management and Tuning
Oct 23, 2012 09:46 AM
vietdragontekx
Honda S2000
Dec 21, 2010 09:55 AM
PARADOX_sf
Sep 1, 2009 01:36 PM
BlueShadow
Nov 3, 2005 08:40 PM
gulftiresinc
Aug 13, 2004 04:12 AM
