b18 axle problems in crx?? need help!!!
Old May 27, 2003 | 06:17 PM
rickyt60's Avatar
Default b18 axle problems in crx?? need help!!!
i bought a crx with a b18a swap into to it and the passenger side mount was welded the wrong way so now the engine sits forward and the axle sits at a slant ,i heard that by buying the hasport kit this problem is solved but i am on a budget ,do i have any other options then to spend 400$ on a kit ,please heeeeeeeeeeeeeeeeellllllllllllllllllpppppppppppppp pp me
Old May 27, 2003 | 07:34 PM
VTECVillain's Avatar
Default Re: b18 axle problems in crx?? need help!!! (rickyt60)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rickyt60 &raquo;</TD></TR><TR><TD CLASS="quote">i bought a crx with a b18a swap into to it and the passenger side mount was welded the wrong way so now the engine sits forward and the axle sits at a slant</TD></TR></TABLE>
How did they "mount" the engine? You might need to return the car back to factory specs withte mounts brackets and such. A B series mount kit is the only way to go: HASport, HCP, Place, etc.
Old May 29, 2003 | 05:17 PM
joey1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rickyt60 &raquo;</TD></TR><TR><TD CLASS="quote">i heard that by buying the hasport kit this problem is solved but i am on a budget ,do i have any other options then to spend 400$ on a kit ,please heeeeeeeeeeeeeeeeellllllllllllllllllpppppppppppppp pp me </TD></TR></TABLE>
bump
Old May 29, 2003 | 05:59 PM
poison's Avatar
Default Re: b18 axle problems in crx?? need help!!! (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
How did they "mount" the engine? You might need to return the car back to factory specs withte mounts brackets and such. A B series mount kit is the only way to go: HASport, HCP, Place, etc.</TD></TR></TABLE>
Chris said it all.
Sorry man. I would definitely return **** back to stock and go with HASPort, HCP or Place racing mounts.
Closenough
May 4, 2012 08:30 AM
greyEG
Jan 13, 2012 05:13 AM
smapty
Aug 29, 2005 10:31 AM
B18aHatch
Aug 19, 2005 06:50 PM
Rocks
Jun 30, 2004 07:47 AM
